How long are the 6950s?
6950 is a great price, that would be the card to get and clock IMO.
You blind..?
Its listed to do with price
Yep, but ive made a few modifications to my case cooling, hung a 120mm 1500 rpm fan behind the cards.
It allows me to use auto fan when gaming, therefore keeping noise very low, temps in game hit 76-77c, gpu fans dont go over 50%, above 60% they do get pretty loud. But i only set the fan to manual when running higher clocks for benchmark runs.
@Gibbo
i believe you can answer this question
if you were building a rig for yourself what will you put inside your system if there is no issue of budget
HD 6970 or GTX 580
GTX 480 1536MB = £250-£270 **EOL**
GTX 570 1280MB = £250-£290
Not sure the 480 is a good buy over the 570. 570 is cooler users less power and slightly better performance.
Not a good deal.
This is a great post though Gibbo thanks especially in this economic climate and XMAS
Remember VAT 20% in january folks.
so glad i bought gtx580 on release, didn't wait for the ati card.
so at similar price to gtx570, for 6970, am i right in presuming it will perform between 570 and 580? it's always ATI's strategy to price their cards slightly lower than nvidia even if they've got exactly same performance.
http://www.semiaccurate.com/2010/12/13/secret-amd-6900s-second-switch/
Single most mind blowing SA article EVER, AMD whoops the 580gtx hardcore due to secret second switch.
