Perhaps your post would be worthwhile aimed at the autosock.co.uk. assuming you want to file a grammar complaint.![]()
There is nothing wrong with the grammar they have used - my post is aimed at you and was explaining to you, in capital letters, what the passage you quoted said.
It says you should ALSO fit them to the front, not instead of, so that advice is not the reason morons are fitting autosocks to the front wheels of an RWD car.
