- 6 Feb 2010
Which actually worries you more? Using higher voltage, or the extra heat caused by it?I'm testing 785/1125 at 1.144V atm. Hopefully I can squeeze a little more juice with reasonable volts out of the card. I'm trying to get the best in terms of temps/noise/volts/clocks. This is how I found a sweetspot with my other 5850 that did 925 MHz on core and 1200 MHz on memory with as little as 1.149V.
