- 27 Dec 2005
- Bristol
Extinct, could you post your launcher dock background?
I don't really have a PSD for the APPS Tray icon as I created that on the fly just to test out and turned out to work quite well so just stuck with it lol.
It's really easy to resize, just select text tool then click the text and choose a size from the top toolbar!
Very nice! You should customize the colours in Jorte to match your icons as well. I like that though
Very nice! You should customize the colours in Jorte to match your icons as well. I like that though![]()
i want an amoled drsire slcd sucks
is it really that bad .was hoping to get a desire hd and they use the same screens i think?
You can customise the themes yourself, when you click "Styles" click customise at the bottom and you can change every single feature to any colour you wantYeah, I did try the blue scheme, but it was the wrong shade of blue. White was ok, but I don't like the black background in the full app. So I picked orange![]()
just take a look at khaaan! or nexus18's phone shots amoled's self illuminate and dont use a backlight so yep you guessed it when theres black on the screen it really is just the blackness of the pannel
with slcd theres a backlight so what you thought was black is just dark grey next to amoled
urm..copypasta
with an OLED screen displaying black the pixels are not on, and power consumption is virtually zero. Each pixel is a tiny LED light source, which is why contrast ratio is so much better on OLED as true blacks can be produced, by turning off light completely, something backlit LCD technologies cannot do.
This is why, for best battery life, dark themes should be used as a full white screen can push power consumption of OLED over that of LCD types.
