Im on Jap Jellyfish RLS3 and took my phone off charge about 24 hours ago and still have 93% left in my battery, for me Jap Jelly RLS 3 has by far the best battery life of any rom out there![]()
It depends what battery draining apps you have running, I have the Wifi always on and GPS comes on and off randomly and I get a day at most. If i turn everything off i can easily get a couple of days use.
Just running this Jap Jellyfish rom and so far i,m quite immpressed. It seems to be a bit more snappy. Angry Birds is far less juddery. I have not bothered with the overclocking and i,m getting 1027 on the benchmark thing. Not sure if this means anything really as i have read it can be quite random..
Will give it a full charge and reset the battery meter later then see how it goes. Only topped charge up earlier to make sure I had enough to install the rom.
anyone know where to buy cheap replacement headphones? for the san fran. I accidently cut mine on new years.
To confirm, I never had a problem with standby battery life, when not using the phone, it will last for ages. This is the same with any of the roms I have tried.
My real problem with this phone (on any of the roms) has been battery life under use. Worst offenders are 3G data connection, internet, downloading and installing apps and gaming. Then add sync, GPS + wifi on top and it goes down fast.
To the point I now keep a spare dumb phone with me in the car.
Most of the time I would get a woprk day out of the phone when on Seb's r3 with pretty heavy use before charging.
Is the Galaxy S really that bad?
Loving this ROM so far, .....................
Is this the latest Jellyfish ?
If so I agree completely.
Although wish a lite (bare) version was hosted, its not easy to know what the additional apk files are as some names are a not obvious. Took my ages with google.
Unless none of it is needed ?
Thanks, but this is how i ended up with the same version as you, good job flashing is easy/quick3B, latest one!
I basically kept re-doing it myself. Installed the full version and checked at what crap there was that I wasn't going to use (pretty much everything), opened up the ZIP and deleted all the crap I didn't want, everything still works fine and dandy. Oh, and edited the 'build' file and added another 8MB of VM.
I'd call this the 'Anorexic' version as the i've literally stripped everything from it apart from YouTube, media player/picture viewer and news and weather. Whatever else I want I can easily download off the app marketplace. Just downloaded TaskKiller and that's it.
Edit: If you want, I could upload my version of it somewhere if you fancy giving it a go.
had it for an hour hardly getting anywhere
