Looking at the Wizzards results, the failure rate is only about 1%.
glad you sorted it![]()
Asus Smartdoctor only work with Asus bios's
Asus Bios as the same voltage has other bios's.
for 6950 it's 1.1v , for 6970 it's 1.175v
Though it was that but turns out it isn't.
Just looking through some other threads and had a thought....
Turns out it is the smooth scrolling option in IE.
snip
•Added (preliminary) support for Radeon HD 6850 and 6870. Everything _should_ work, except for voltage modding.
•Fixed minor WinFlash version detection bug.
•Improved built-in hex editor search functionality (again).
•Improved flashing procedure for more stability.
•Fixed Dell Subvendor-ID, thanks to Clinton for the tip!
GJ02 - it's possible to change the core volts via this method - look for the following app on the techpower web site RBE_126.exe but remember this will pump the volts you set on card boot so take it easy if you chose to go this way.
mg - did you use the Asus 6970 bios?
