Yep. I also tried two ways of flashing with each card, one was done the CMD way, and one using this. It has a BAT file in it that you run which does everything for you, so it's just a single click to flash!how did you flash them, take one out and flash 1, then take that out put other in and flash ?
Theres a empty PCIE in between them but theres only about half a cm gap between the cards... they get well noisey in crossfire after flash though. I've clocked the cores down to 820mhz so it's somewhat bearable. If yours is fast enough and you're only using 1080p res then i wouldn't bother flashing if you go crossfire because of the noise.on your ud7 have you got the cards spaced appart ?
) 6970s! Fans not too loud either and when the long Xfire bridge gets here I'll run em spaced apart better and they'll have better noise levels ... I doubt there will be noticable impact @ 16x/8x PCIe. Just wish I got em when they were £200!
Guess i'll try some better case cooling and space the cards more apart, see how that goes. I've got things water cooled so theres not much air going through the case.
