- 19 Oct 2006
Surely you can RAID with the two SATA 6.0Gb/s ports?
So if you use integrated GPU you can't overclock cpu, right?
Does it mean that if I use regular graphic card in the slot, can I OC cpu?
Second thing: H67 = no RAID for SATAIII?
Also - what is UEFI?
Well order placed today. Went for the foxconn as its damn cheap (cheaper than the others will be) and will tide me over till P67/Z68 mITX later in the year.
How well does the integrated graphics perform with windows aero? I used to have an ATi 4350 and that used to stutter with windows aero and wasn't as smooth as I would have liked when scrolling fast, hence why I now have a 4670. However, if the integrated graphics is decent enough then it would free up some space in my case by not needing a discrete card, which would be great!Yes! First impressions of the Foxconn are that its very well put together and header placement is nicely thought out (for the Lian-li at least). It doesn't have UEFI but it can have UEFI in the future (I'll probably have moved on to P67 by the time Foxconn get around to that). First impressions of Sandy Bridge. Its fast! a huge step up from my Phenom 8600.
Currently having a couple of driver issues with my HD6950 but thats AMDs fault for having rubbish drivers. As a result I've been using the onboard GPU which is ok. Not great just OK. Haven't really had a chance to properly give it the beans as I've been trying to sort out my damn graphics card (roll on 11.0).
My memory (XMS3) is running at 1333MHz (max for the board) at 1.65v and its not dead yet. I've looked for a way to lower the voltage or the latency but evidently H67 doesnt support ANY form of overclocking not just CPU.
The board is nice but with no USB3 and 3 SATA ports its not for everyone. As I have said before it is only a holding card till I see a P67 with UEFI, USB3 and 6x SATA ports. If I wasn't going to put a raid array in and didn't want to overclock I would certainly stick with this board and for the price its bloody excellent.
