Is Tom helping you by any chance?Could one not make the panels oneself, cutting their own fan holes etc into sheets of aluminum (If one was not aiming high as far as looks are concerned
If I wanted simple, then cutting panels would not be a problem.
What I am having problems with is getting a design from paper & putting it into a program so the panels can be laser cut.
My design will not be simple as I see this as a blank canvas.
I have the opportunity to do something uneek & I am taking it.
As for Tom, he is getting the panels cut.
