- 11 Jun 2009
Just did a count. 52 ladders every other block. 104 blocks down x 3 x3 = 936 blocks. Just mined nearly one thousand blocks for nothing! Is it wise mining horizontally right above bedrock, or should I just start over?
It's annoying when you set up your 'home', get it all nice and how you like it, then start mining and there's nothing to be found... happened to me twice now.
You won't find any caves just above bedrock..
The trick is to build a home near a hill that has lots of natural caves in/around it, it will be the same all the way down.
