So if I was going to SLI in the future you recommend getting rid of the 480 and getting a 580?
Forgot to say yesterday, i did bump the volts up to 1.1 for that run, its stable @ 830 on stock so probs wont need it that high, i just wanted to see what kind of score it would produce, will try stock and lower mV tonight.^^ Looks about right for 850 core, temps look high though. I got the same case, cards get toasty with no side panel ventilation which is not helped by the HD cage restricting the front fans air flow.
got it all off now and my ek-fc580 waterblock and back plate on it and it stays at 39 - 45c at load now which I think is goodWell my pair of "cheap" Asus 580s just turned up from 'the big river'![]()
Hopefully get chance to install and test them later![]()
Ok, just ran Heaven, how does this look for a first time.... Not really tweaked yet though...
Good, bad, average?
i7 is @ 4ghz despite what heaven says.
gonna sound like a noob but can you flash the bios of any 580 to another one?
The heaven bench is BS too...Its flaky and really ignores stuff like CPU speed which is a biggy in games
