I'm in
Scary volts as it looks like I've got a crap chip - relatively speaking of course
My normal clock is 4.7ghz and that needs 1.485v in the bios. Can live with that though. If it pops, it pops
8 hours prime stable so far
Got a new WC setup too which I've been tinkering with over the weekend, so my system is silent at 4.7ghz thanks to viper fans only getting upto 50% to keep temps to about 68-71 degrees. Thats in prime. An hour on mafia 2 'spiked' my temps to 55 degrees
Using a EK HF block, and a BIIIG rad
Has made a huge difference to gaming by the way as I recently purchased a 570 gtx and it was bottlenecked by the q6600 I had at 3.2ghz. Some games are now so much quicker, and they werent really slow before.
The best example I've seen is resident evil 5. I was getting, at maximum settings at 1920 x 1080, around 98 fps. Now, with the 4.7ghz overclock, its gone upto 160 fps using the benchmark. The best thing about it though is the minimums. On the q6600, the resi 5 benchmark graph had peaks and troths covering a big range of numbers
Now, its a completley straight line. Not one drop.
