Hello Dazboot You have a good CPU and your board is fine too.
Here are a couple of tips to help you break your 7sec target.
Open Super PI
Run 16 twice
Run 1 Mil once
Open Task Manager
Set affinity to CPU 04
Set Priority to High or real time if you have a stable overclock.
Make sure that all the stuff running in the background like AV or downloads are closed.
Close all the stuff that you do not need in task manager.
I have 12 services in total including explorer running when I bench
Have fun
OH Thanks for that looks like im going to give it another go in a bit
This is understandable really when you think of how many they have and that they are all boxed / stored in the warehouse. The only way they are likely to see the benefit is if there were one or two golden batches that were identifiable that they could sell at a premium (well that's the way I would think). But, correct me if I'm wrong, there is not really an identifiable golden batch... There seem to be some good ones from all sorts of different batches.
