I can't. I can find you an quad core Intel that would steamroll a Thuban for about £50 more though.
But i want a hex core not a quad.
What's the point in having a slow six-core when you can have a (faster) quad core? What are the benefits?
You have no good reason to want a six core when there's a quad core available to you that is faster in every way... especially in single or dual threaded programs.
Therefore I'm putting it down to ignore and/or fanboyism.
.Is there a particular reason that you'd want RAIDed SSDs for your OS? Why not just have a single SSD with your OS (backed up regularly to your 10 TB RAID5 array)?
Seriously, write cycles aren't worth worrying about at this stage - average lifetime for current SSDs should be longer than that of HDDs.
In theory yes, in practice it'd probably be hard to notice a difference. Maybe with lots of VMs it might be obvious though.
Regardless, a single SSD will spank a RAID 0 HDD setup. Personally, I'd discount using HDDs for OS drives for such a system.
1) Your facts are wrong & its been proven time & time again so its you who are ignoring the facts & is the very thing that you call me because you can say that about any AMD user & like you have any idea of what program's i'm running & how many im running simultaneously which would stall a quad core & again at a cost cheaper than Intel that you ignored again.
2)The best you could do find was a more expensive Intel quad CPU to beat the AMD 6 core in single & dual threaded programs, if it cost more than it damn well should which is a total contradiction of finding me the equivalent for price & the accompanied motherboard would make the price gap even more so .
The total cost of Unlocked multi CPU, Ram, & Motherboard in my configuration that will take everything that i needed is simply not worth the % of performance to price.
The fact is that AMD offer good performance at cheaper prices which means i can spend more in other areas which make a more noticeable difference like on the gfx which many on-line articles have pointed out.
SD is out of the question as its far to fragile, i would kill it in under a week.
I upgraded from a Quad to a hex core because i needed to & not because of an upgrade bug, & i need true cores because i have allot going on at the same time & i don't like having to close things if i don't need to.
If AMD start to cost more than Intel in price performance ratio which tailored to many needs which are many things going on at the same time then i will be switching over to Intel.
But of course from now until then there will be numerous other narrow mined users questioning me who have not read my history which i will then have to repeat it all over again.
Any more news on bulldozer being compatible with am3?
Does it even fit in the socket?
Firstly its worth pointing out that a run of the mill motherboard performs identically to a £300 mobo, the chip and chipset are the same, the daft shape of heatsinks changes to one that looks like a M1 magazine, thats about the best you can expect increase wise.
Sandybridge doesn't beat a hexcore in everything, most things yes, it depends ENTIRELY on what programs you run as to if that extra speed will matter in the slightest.
The simple fact is, if a £140 chip gets you the performance you want, with a £80 mobo, why would you pay £263 for a chip thats faster, but not always, and you don't need, with the general idea you'll pay a lot more for a similarly specced mobo on top of that.
Also can you please find me a 6 core Intel with fully unlocked multi for £200.
Is a 2600k Sandy bridge at £263 retail really worth 50% more than a £140 hexcore P2, is it 50% faster average, across the board....... if not they how on earth can you argue with his other point, the extra money doesn't give you the same performance percentage increase, as the cost increase, therefore its less good value.
Maybe you can get away with 4 cores, maybe the apps he plays with all day will be faster on a hexcore P2 than a 4 core 2500k without HT, yet would be quite a bit faster on the 2600k with HT, who knows, but even then the answer to what you should get is, best value while doing what you need.
