Did some testing in heaven 2.5 @ 1920x1200 default settings.
Default CCC settings also
What you will see on line two, is when you have a registry lock on your cards. What i mean is by that is you need to disable ULPS power saving modes in registry to allow something like AB to oc both of your cards above 840/1325Mhz without BSOD for you
by adding +20 on your powerprofle in CCC i gained .1 fps in max fps area, nothing else. Prollt help stabilise if you push above 880/1325.
http://3dmark.com/3dm11/889599
p9026 with a gfx score of 9324
