Yeah I'll run it again later. Before the cleanup I did and I was high 70's/mid 70's.
hi Hank
i have a similar setup
Q6600 (B3 version)
Tuniq Tower 120 (fan on full for testing
)my temps at 3.3GHz are high 20's idle and mid 70's running intel burn test.
the tjmax should be 100 for a G0 version but
when running realtemp, just keep an eye on the distance to tjmax. never let it go lower than 20
this never changes even if your tjmax is set wrong
before running Intel burn test, open task manager and see the amount of free ram.
for example i have 2550mb free ram so in IBT i enter a custom amount of 2500. (just below the free amount)
then i change the threads from auto to 4 (quad core)
now every run i make i always get around 40-42 gflops. (consistent)
wingzero30 explained all this a few pages back
" I would choose 'free' memory as available memory will also make use of cache memory which must be storing data for other applications aswell. Windows may free up some physical memory from the cached memory during testing but not totally and i think the rest will be the virtual memory as a compensation.
Available = Free + (Cached - Modified)"
running just free memory will help you get higher gflops, as its just using free ram and not cached ram
this should also have 4 or 2 cores running at 100% (or how many your cpu has)
this will give you more consistent gflops score, but will also make your temps higher, as more gflops, the more the cpu is stressed
