guys unsure what to do, seems to be a mixed back if a different network carriers sim will run? can i ask who took advantage of the o2 deal and then stuck a diffident sim in. i see above fen739 had no issues.
Just out of curiosity what is it about the iTunes market that makes it better, is it the iTunes bit of it, or just the apps available, and if the latter than what apps in particular?
End result = battery at 95%, at this rate it'll still be >90% when I get home after a days work![]()
okay so copying my SD card contents to the internal memory right now as the SD card is seen as "external sd" even though internal mem is seen as "sd" lol so some apps fail to find the sd card where their backups are stored. Simple enough process to migrate contents to internal mem really.
I wills ay this, compared to the Desire this thing flies, the screen is wonderful
I want to get the stock Android keyboard back as I don't like Samsung's one and I also want Widget Locker but all that will be done later as I mash in stuff from CM7 after rooting.
Will do a proper review compared to HTC Desire tomorrow maybe and also compared with other phones I have had extended use with (iPhone 4, Galaxy S etc).
I've also ordered 2x cases, one will become my new DIY dash mount holder so a mini project on that over the weekend. Also ordered an Android sticker, just because![]()
guys quick question about the SD card...
I dont know much about the different classes but I understand its something to do with the transfer speed?
Well I wanted to get a 32gb micro sdhc for this and all the ones I've found are only class 2...but I believe the classes go up to 10?
So is this card going to be really slow? like stuttering when watching hi-def films or something?
thanks
Aimed at jimlad
A poll on xda shows it's about 50/50 if your phone is locked if you bought it as pay as you go on o2. Eitherway it can be unlocked in under 10 mins and costs £15 so no big deal.
My O2 PAYG is locked. I am waiting on the unlock code from a third party for £15
While iTunes isn't the best piece of software I've ever used, Android simply has nothing like it. It is useful and it does work very well, I won't really miss it though as I don't buy films and music with it.
Generally, nearly every single iPhone app is better. They tend to be more stable, of a higher quality and often developed by the companies directly (big companies, like BBC, Sky, etc) and I just think a lot of the Android apps feel like poor knock offs in comparison.
There are plenty of good ones though, and the superb browser and flash support means I can get by without the iPhone ones with no trouble
Android games are absolutely shocking in comparison too, but thankfully there are plenty of good ones and I dont play games much anyway![]()
That is ridiculously good![]()
thanks
thanks
So the card you need will depend on the bitrate of the HD video you want to watch. A class 2 card will have a 4000kb/s video stuttering.
thanks
Maybe im being stupid but is there a shortcut to enable/disable network data connection?
Also, be wary of a well known shop selling PNY class 10 cards cheap. They are not PNY branded and do not conform to the class 10 specs.
The one i got benched at 20mb/s Write and 28-30mb/s Read after i set the block size to 2048K
