the specs are very poor, it will eventually do what you ask but there a lot of better phones out there. Whats your budget?
Budget is around 100ish - if it's really really worth the extra, maybe a little over.
OK, so I tried to order and after the Secured by Visa screen it said the transaction was unsuccessful. What should I do now? The fact I am using Chrome anything to do with it or do I just try a second time? Very frustrating.
for less than £100 - Orange San Francisco has a much better screen and resolution and great modding community to make the phone even better.
there's an ocuk thread here - http://forums.overclockers.co.uk/showthread.php?t=18189628
I think the Orange San Francisco is still considered the best Android phone for that price point. If you replace the firmware with custom it's a pretty damn good phone for £100.
the arrows will flash if the mobile data connection is actually being used - when using the web browser/youtube and when apps are syncing for example.
Download 'speedtest' app to see what 3g/H speeds you are getting - 1Mbps+ should stream ok.
And no GPS would be better left off unless you really need it for example navigation.
battery full notification anyone?
Today, I decide to check my e-mail and see that o2 are already charging me as despite not having the phone, my contract began on the date they thought I should have received it.
Got an annoying problem when changing my wallpaper.
When I change the main wallpaper its also changing my lock screen wallpaper which I dont want it to do, anyway to disable this?
The loud one that woke me up last night? Yeah, I've heard of it.![]()
