A big thank you to to the people in this thread!
Special mention to Cenuij for the photo & caps list & to Diggsy who gave me the link to this great info.
I have just repaired my monitor
& it works
Never again, as my eyesight is not good enough for stress-free soldering unless I get those glasses the surgeons use in the operating theatre.
Only C111 appeared to have gone but replaced all except
C107 as I couldn't figure out the solder points in what appeared to be a group. I did buy a C105 , more expensive than the rest put together, but it was a snap in, legless, as most of the type are from Farnell & so there was no way to solder it to the board.
A final point on Caps.
Farnell have a minimum of £20 spend so I got the soldering kit from them as well.
RSSS only appear to sell most of the caps in x5 packets or x2: C105 is the exception
Apart from the soldering, I had a 25w iron & maybe needed a finer tip than 4-5mm. Samsung seemed to have used melt resistant solder
Use a paper clip to clear the holes. Everything else went smoothly apart from the "pink & blue" connectors that were a real challenge to remove.
Hopefully I'll get another 5 years out of the monitor now
