I have a standard unrooted SGS2 sim free from CPW. Did the KE2 update and had serious problems. EVentually reset the phone to factory standard and had to reinstall all my apps and sync my contacts and calendar individually. Kept crashing otherwise.
Did you manage to get any better answers from T-Mobile regarding this Mammalian?
Argh! Dust! The one reason why I hate wrap around cases lol. Wiping away dust is a chore because it just collects at the edges and since there's no edge falloff on a wraparound case....well you get the picture.
I might trim off the bottom wrap lip on the case so then I can just wipe dust down and off the screen![]()
That would be highly hilarious if it is only Orange users with this issue.
is there a changelog for these updates?
No it's fine. There's any number of guides, but basically flash it with ODIN. See below, but look for the latest firmware on XDA or www.samfirmware.comI tried to upgrade using kies, took about 5 minutes then dll fail error message and the phone is sitting with a android icon and says "Downloading...Do not turn off target!!"
Have I screwed this thing up? What can I do to get it back to full working order?
Thanks
For manual update if you're having problems with Kies
1) Firmware
Download the correct firmware for your phone. Extract the zip file to a tar file. Do not extract the tar file.
Sim Free Firmware - I9100XWKE1_I9100XXKDJ_I9100XEUKD1
O2UK Firmware - I9100XWKE1_I9100XXKDJ_I9100O2UKE1
2) Download Odin (flash utility)
Odin3-v1.85.zip
3) Prepare Odin
Launch Odin and check "Auto Reboot" and "F.Reset Time"
Load the firmware downloaded in step 1 in PDA.
4)Download mode.
Put the phone in to Download mode ready for flashing
- Power Off
- Press and hold Vol Down + Home + Power.
- Once the Andriod logo is displayed connect the phone to PC
- in Odin ID:COM will turn yellow. You are now ready to flash.
5) A Successful Flash
6) Factory Reset (Optional)
There are three ways to reset the phone, through Dialer, Settings or Recovery mode.
- Dialer, enter *2767*3855#
- Settings, Privacy, Factory data reset.
- Recovery mode. Power off the phone, press and hold Vol Up + Home + Power. Use the Vol keys to navigate the menus and Home to action.
yeah i know what you mean. when i saw you had the same case on the last page i though i'd ask if you have the same problem but looks like you do. my solution to it is to use the spinning galaxy live wallpaper as then the dust particules just look like the starsshould try it as it looks better.
which is the second case you'll be using for the car mount? can you put the current phone and case into the car mount? as the case is fairly well put on it's going to be hard to take it off every day when using as a satnav/mounted music player
3. How do I change the 'theme' on the desktop for want of a better explanation?
Thanks.
