If Samsung had used their PenTile technology in the screen then it would be no contest but the qHD Display is looking like a winner in the Sensation.
Yes the viewing angle isn't as good and looks more washed against the high contrast of AMOLED but it still is 480x800 (Old tech) more and more apps in the future are going to be designed and aimed at qHD displays IMO
If Samsung used the pentile matrix it would be worse as this technology is old. SAMOLED+ uses a proper arrangement for the pixels and is very close to LCD screens.
Get your learn on @ http://www.oled-info.com/super-amoled-plus
Resolution matters very little here and it's a bit of a stretch calling 840x480 old tech and there has been no confirmation from any source/dev saying apps are shifting to qHD only at any point now or in the near future.
If you look at comparison videos of the GSII and Sensation side by side you can easily see that what's on screen on both phones is neck and neck. It's not like HTC have allowed the Sensation to fit an extra row of icons on the app tray or homescreen.
, I'm not a samsung user, I use Android and windows phones that just work independant of crap software, Sure You will tell me there are ways of getting around these sorts of problems.
It works just like any other Android phone. You don't need to install any software at all as Robbo pointed out before you threw all of your toys out of the pram at him.
