tu es très gentil! being the complete chicken that i am and scared of bricking my lovely phone.. any chance of xda linkies? I *think* i found the "crt" effect thread but no idea about the circle one.
muchas gracias!
From the OP, download... http://forum.xda-developers.com/showthread.php?t=1064037
- SystemUI KE7.apk
- Framework-res KE7 battery mod and CRT fixed.zip
Using the USB cable, put both files in a place on the phone storage where you can find it... I made a folder called APPS & MODS. Rename SystemUI KE7.apk to SystemUI.apk.
Then unzip Framework-res KE7 battery mod and CRT fixed.zip and inside you will find a couple of folders, but the important file is framework.apk.
Now you need to ditch the USB cable and use Root Explorer (make sure you enable r/w permissions at the top right, small grey button) on the phone to copy the files to the appropriate folders.
1) The modified SystemUI.apk needs to be copied and pasted into the /system/app/ folder on the phone. I recommend renaming the existing SystemUI.apk to SystemUIold.apk before doing so. Once you've done that, power off and reboot.. and voila, green connection icons.
2) The modified Framework-res.apk needs to be copied and pasted into the /system/framework/ folder on the phone. I recommend renaming the existing Framework-res.apk to Framework-resold.apk before doing so. Once you've done that, you will get force closes, this is normal. Power off and reboot.. and voila, a circle percentage battery indicator.
One side effect is that my Google account setting dissappeared... so I just had to set that up again. Also my wallpaper reverted to stock... again, easily fixed.
That's all there is to it, and it worked perfectly for me.
