- 3 Oct 2009
- Wales
I still have chest doms from thursday, this is madness
I never get DOMs
I obviously don't work hard enough then !![]()
There are plenty of better exercises you could do while you recuperate. Also, I really wouldn't work my biceps in between pullup sets because you'll just have your biceps failing before your back, thus robbing your back of a workout.
It tends to be very tempting to work your biceps as a beginner because they are "obvious", don't fall into that trap
If you don't want any rests, look into supersetting opposing muscle groups. For example, do some flat bench and then some bent over rows straight away with no rest.
currently I manage around 9 sets of 8-10 pull-ups - I find them quite easy so I should get a weight belt- but they look quite unweidly
Nitefly - palms facing forward- full hanging to chin above bar
palms backward its 6-8 sets of 6 reps
probably all those biceps curls - lol - as chin-ups use biceps more than pull ups?
it helps I only weigh 62kg - so makes power to weight ratio easier to be advantegous when it comes to body weight exercises - its a bit of a cheat I suppose
£15 for the 1kg bag?
