Where is everyone getting the cars is there a decent car pack somewhere?
It would be nice if someone compiled a list of essential mods for GTA 4Like, gfx packs, car packs etc etc. Any volunteers? You will get many internet cookies
Not really, it's best to replace them individually as you're bound to dislike some of them.
I use the Realistic Driving EFLC mod to replace all handling files and don't touch them after replacing the cars themselves. Just make sure that you find adequate cars for replacement or else you must use their own handling values.
You can find models here and here and use Open IV to install them.
There isn't any, tbf, the mods are all different and likely to cause problems when you run into compatibility issues.
For anyone attempting to try this mod on their Steam copy, I can confirm that the mod installs and works without issue when steam is fully closed down.
If this it's of any help then here is the process I used for my first time install:
1. Turn off steam
2. Make a duplicate copy of the GTA game directory
3. Check exe version number, mine is 1.0.7.0 how do you do this?
4. Download the patch from this site
5. Extract the file and read through the readme
6. Copy from the referenced files into the GTA IV folder What do you mean by this?
7. If you are not asked to replace files then you have copied into the wrong directory
8. Run the LaunchGTA exe the one in the copied directory?
9. It will state that an xlive.dll is missing
10. Go to installables folder
11. Install the GFWL and the VisualC files
12. Try running LaunchGTA exe again and it will start
13. It will ask for your CD key so close down the game
14. Start up steam and go to your library
15. Right click on the GTA IV game link and choose CD key and note it down
16. Fully close the steam application
17. Run the LaunchGTA exe from the copied directory?
18. Enter the CD key and now setup your graphics and run a benchmark
19. When secuROM asks you to log in, just choose play offline
20. Yay deal with GFWL... Log in, download profile, download update, restart game, log in and enter CD key
21. Enjoy the game
Don't forget your manners, if this helps you then say thanks.
for only £6 im tempted but i bet it wont turn out like that video. Anyone have any real life screenshots to share?
I completed the game plus all DLC on xbox but it looked ugly as hell
Krugga can you also also use those mods with steam versions? Gonna buy the GTA 4 complete pack from steam I think.
Yes, the screenshots above are taken from the Steam BoGT version.
And the patch isn't available on Steam as Steam updates the game automatically to 1.0.7.
So can you or cant you apply it on the steam version??????
It does look as good as that video but you need patch 1.0.4 for that to work.
I've read that it works for some people, but others get horrible fps
ill hold of buying until more people can confirm the steam version works
[TW]Fox;19530597 said:These mods look amazing.
Can I still play online with modded cars etc?
Is there a way of getting the files from a 1.0.4 patch and overwrite the files in steam? So it sets it to 1.0.4?
If you could actually read,
