Out of interest are you doing the handling & carcols files as well ?
its one of the problems with icenhancer at the mo. If you find a fix let me know.Anyway to tone down the amount of light in the daytime? It's far too bright.
Oh great, I've just tried the car pack and I'm getting the TAXI bug! Nothing but Taxi's and one car type.
Any ideas for fixes?
TrafficFlow Description said:TrafficFlow is a list of 20 vehicle models that comprise the 'vehicle pool' which Traffic Flow will randomly select 3 vehicles from every 15 seconds to load into the game's memory. Also makes Emergency services respond to calls throughout the city.
TrafficControlSystem Description said:This script adds AI based traffic with a random selection of vehicles. This does not “remove” the taxi bug but does make the traffic look proper. If you wish to lower taxi spawns lower your traffic density. This mod has been tested with LCPDFR and ELS of which are compatible. Please take in consideration that this will greatly raise your resource requirements when spawning a high density of traffic plus the AI cars if you experience lag lower your graphics settings.
Well I solved the bright issue abit, deleting the icebloom.fx and the one with lightshafts on helps.
Only problem is, my screen is flickering now :\
Nice work Mayfair!!
Unfortunately something went pop and the game would crash on startup. I even tried deleting the modded version and copying over my vanilla backup. Didn't make any difference, every time it would crash immediately after the black screen with white text at the start.
I couldn't get the taxi fix to work on my indtall, just got taxis and BMW's!
snip
I just need to see if my puny 470 can have a little AA![]()
