- 24 Mar 2011
- Cambridgeshire
Many new TV's have a glass front and the glare really isn't so bad.
My college spent a small fortune on mac pros and their cinema hd screens, along with a few extra screen because they're very good quality for the design students.
The Apple Cinema screen uses the same LG panel as the Hazro so if that's any indication it shouldn't suffer that badly from glare. Also Hazro stated in OCUK that there's an AG coating on both the Glass and Non-Glass monitors.
I think the AG comment is a slight mis-quote on Hazro's side, seen as their own website doesn't mention anything about an AG coating. And claiming something is glossy and anti-glare is a slight contradiction in itself surely?
Also, the glass is uncoated so will reduce transmission (from the panel) and induce surface reflections on the outside. It's effectively like looking at your monitor through a window. It will be easier to clean and glass is hard so it won't scratch as easy as the panel surface, but there are no image quality improvements from having a sheet of glass in front of the panel itself.
