Caporegime
- 18 Sep 2009
- Dormanstown.
Now your taking complete rubbish.
All my games i run at 60fps.
Dawn of war 2 at 1920x1080 with my two 6870's doesn't on a Thuban at 4.375GHZ.
Dirt 2 and the like ran perfectly fine at 60 FPS, even at stock speeds.
the thing is, there is defending something that isn't performing and there is defending a processor that does a job, just not quite as well as a much more expensive rival. don't see the logic, its half the price yet it gives much more than half the performance, where is the logic? could perfectly understand your argument if the Phenom II was £200 and facing off against a Sandy Bridge processor of similar price and performed like they do then fair enough.
the fact is that a Phenom II X6 can be had for not much more than £100, they overclock well without having to get a more expensive 'K' edition and will handle anything, anything at all you want it to do. fair enough it might not do it quite as quick as the Intel but that isn't the point..
Edit: in-fact would consider it rather pointless to go for an Intel processor at the moment, when I could get an X6 for ~£110 and a decent motherboard, all adding up to like £100 less than a similar Intel setup, not when both do the job without much trouble. for gaming be better of getting a better hard drive or better graphics card to be honest.
Brand new 1100T gets pwned by a 2100 in many games, which is more expensive? The Thuban.
http://www.overclockers.co.uk/showproduct.php?prodid=CP-267-AM&groupid=701&catid=6&subcat=1944 1055T 125W
http://www.overclockers.co.uk/showproduct.php?prodid=CP-363-IN&groupid=701&catid=6&subcat=1275 i5 2300.
SB will walk all over it, and only 10 quid more expensive.
