Caporegime
- 18 Sep 2009
- Dormanstown.
Though the in-game benchmark has since changed since then (i.e. performance figures are lower now than when i had my 965), that is exactly what it did.
I'd also doubt the veracity of your statement, and mention of it as an illustration of 'better' SB performance / lack of need for more cores, for the reasons I just outlined.
Edit: Just saw your post where you state that your Thuban at nearly 4.4Ghz couldn't run DOW2 at 60FPS at 1920x1080 . Either you had the worst optimised system in the history of mankind, or some serious hardware / driver issues.
Edit 2: Just did a benchmark to prove my point. For anyone not in the know, the benchmark in the game really is extreme, so if you're getting average 60FPS here, it's very unlikely to ever dip below that in game. Before you say anything, 'Rain' being disabled is for streaming the game as the encoder doesn't like it (and there's no rain / weather in the benchmark), reflections are off because they look ugly (and they're not CPU dependent at all), Physics is off because it tends to result in ragdoll bugs which are distracting (and it makes almost no impact on performance at all ... maybe 1-2FPS tops, average. CPU is 3.9Ghz for this.
Run it maxed out, nothing less.
Never had Phenom - had Intel at the time- but theres nothing I cannot play with present X6 1090T/gtx580- combo at 1080p resolution. Gets the job done very well, no complaints here. And my guess is theres quite a few Phenom II´s around the world.
Has it been bad selling CPU?
I've probably bought over twenty Phenom II's since it's launch, as I've built a lot of rigs using it.
