It is actually possible to post more than one picture in a post.
Spits coffee out.
i do realise, but i feel its faster to do it bit by bit, + there are only some pictures im using
http://img593.imageshack.us/img593/7151/dsc01694a.jpg[IMG][/QUOTE]
Uhh... what's with that tiny red fan? :p
Please, go in to your infinite wisdom stulid and tell us mere mortals how to perform the act of adding more than one image in to a post!![]()
It seems like ZZZAC has another fan-tastic idea up his sleeve...![]()
and heres the rest of it
urm, okay, well im sorry i live in a Victorian house, i have stuff to do so my house is "lived in, not in showroom state, and i dont have a frickin high quality camara, is that really a sin considering i can even afford a replacement for my secondary monitor wich is crt wich i use frequently? hmm you forget im constantly, and i mean constantly strapped for cash!
The bit that's been burnt with an iron? That'll do it.
Not to nit pick, but the 5830 is in the lower full-size PCIE slot that only runs at x4 speed. When you (hopefully) remove the card when you install the CPU I would suggest reinstalling it into the upper full-size slot that runs at x16 speed.
Also, why is there a small florescent fan attached to your CPU cooler. By the look of it and the direction it is facing it is likely to do more harm than good for cooling.
Also, you may want to put the memory modules in the blue slots. It should work fine as it is, but it just says: "we recommend that you install the memory modules from the blue slots for better overclocking capability".
But apart from those small things you look good to go. May I ask what the situation is on getting a CPU to complete the build. Are you still waiting for scammers to get back to you?
(Btw there is a fella still selling a Phenom II 720BE on the MM for £65 inc. -it's a decent CPU and will get you up and running).
