Used to be able to get it in kalemsoft.com/betas. However it seems that it's been removed...
Do you want me to email you it? Send me a message in trust if you do.
I've got an ipk of a kalemsoft player, but don't know how to install it!if I try and run it from the browser after downloading it it comes up with a mime type error
how do I install an ipk?
cheers
Tom
Thing is though, it actually helped me play iPlayer, and it gets TVCatchup to load, albeit poorly.
The preware application lets you load ipk files. Various guides exist to do this (fairly straightforward imo) I used this one: http://forums.precentral.net/hp-touchpad/293028-new-touchpad-heres-your-get-started-guide.html
rp2000
Anyone else just had QuickOffice update? Absolutely love the new version.
update with pics please!
If the ipk is on your PC use WebOS Quick InstallI've got an ipk of a kalemsoft player, but don't know how to install it!if I try and run it from the browser after downloading it it comes up with a mime type error
cheers
Tom
had not really thought of that, as i don't use the card button much and just swipe up from the bezel, having said that, any recommendations on another case?
http://forums.precentral.net/canuck-coding/194832-webos-quick-install.html
shame the inside is in teal. please do post back when you've got it as for £3.79 it's worth getting until something better comes along. would be nice to have in a green version
I've ordered one of these: http://www.amazon.co.uk/gp/product/B004075MTS/ref=oss_product
I'll let you know how it goes when it arrives, but ipad and TP are very similar dimensions, so should fit ok.
not having much luck on finding an official case, has anyone bought one of these?
http://www.ebay.co.uk/itm/ws/eBayISAPI.dll?ViewItem&item=280719384765#ht_868wt_905
. There are still the odd ones in Argos and currys, go into your local store, ask them if there are any stock of anything, and they can tell you what shops have them, and reserve them for you!
nursery???EDIT 2: just tried YouTube 1080p on mine and it is a little nursery
