My WC works fine with the 6990 card, no problems .
Hazro already stated it's firmware.
It seems it's upto AMD to sort out their cards problems. As such I'll be sticking with NV if I can to avoid problems.
Does it come up as a Samsung Syncmaster on your machine?
It comes up as Generic PnP monitor on mine. I will check tonight nad post what it comes up with (definately not a syncmaster though)
Yup, was a SyncMaster on mine. Will check with the new one when it arrives tonight.
Just an update, mini-displayport to displayport arrived and no problems with the WD now, appears quality issues were related to the HDMI connector (so probably the scaler was causing the sharpness issues).
Nice one . where did you get it from ? I am using the one that came with my 6990 but I have noticed a few times now , a little 'glitch' flashes on the screen the odd time ,just for a split second say when watching a movie for example (BlueRay) .... I hope the screen is not faulty but I cannot rule out the adapter/ cable as I am sure they are cheap as chips !
Which one ?Okay, have new monitor sitting in box, will update when it's all running.
