http://forums.eidosgames.com/showpost.php?p=1674466&postcount=1
Thought some might me interested in this mod to enable a debug menu to add items and things.
It also disables intros and i think it had cured the stuttering issue i will have to play for longer to see if that is true as i have only been playing with this mod for about 5mins.
You have to overwrite a file but make sure to back it up.
As i have just completed the game it will be nice to be able to add weapons and mods etc too have a little fun with the game on my second playthrough.
So... you go through until then with say, full Inventory, and you are then going to manage without those extra inventory slots for a bit? That sounds a bit dumb.
This sounds all too much like a twist on the MJ12 Facility from Deus Ex.
Must admit I'm getting a bit skeptical as to how exactly they can just slip this DLC in mid-game without ****ing with the storyline.
To some extent, although nothing like the same level as Fallout. It's much closer to something like Thief 3 if you placed that. There are certain areas (hubs) in the game you can go and explore to your heart's conent, but each of them probably only contains a max of about 10 buildings you can explore. You're also railroaded into following the narrative after a while. If free roaming and the ability to do your own thing indefinitely is your thing then you probably want to look elsewhere.
51 hours? And not not even on the 2nd boss? Yeah you've been afk >< It isn't physically possible to spend that much time in the 2 hubs short of checking every corner 5 times over.
I'm on 21h and not reached the 2nd boss yet.
21 hr before the second boss is easily possible.
