http://www.amazon.co.uk/Remington-M...7460/ref=sr_1_1?ie=UTF8&qid=1315425903&sr=8-1
That was on the 5th grade though, normally I use it on the 4th.
Best thing you can get for just £25.
Indeed. I got a Edwin Jagger DE89L for £22 and it's fantastic. I shaved so fast last night I couldn't believe I didn't cut myself once. If I'd shaved at that speed with my old Merkur 34C I'd be bleeding from a few deep wounds.How cheap are you talking, you don't get much cheaper than the Edwin Jagger DE89 and it is a quality razor.
Traditional Shaving (http://www.traditionalshaving.co.uk/)Do you know a reliable UK source for these?
Any forum-favourite sellers?
Remington Barba
looks like i am going to try a DE razor, have been using a wahl sterling 2 electric trimmer for a few years after getting rashes on my neck from the cartridge shavers, going to get the starter kit from tradition shaving but need to wait for the merkur 34c HD to come back in stock because that seems to be the go-to shaver for beginners!
Thank you.Indeed. I got a Edwin Jagger DE89L for £22 and it's fantastic. I shaved so fast last night I couldn't believe I didn't cut myself once. If I'd shaved at that speed with my old Merkur 34C I'd be bleeding from a few deep wounds.
I think its the slightly longer handle on the DE89L that lets me get a smoother shave on my neck, quicker than I would with the Merkur. I'd have to make 4-5 passes to get anything like a smooth neck and even then there'd be rough patches. Now I do 1 or 2 passes and my neck is smoother.
Right, a year and half ago (approximately) i bought some shaving soap and 50 blades. The shaving soap is finally beginning to run dry though i imagine there's still a month or so left in it, still got over 10 razors left though! (whole lot cost less than £30, bargain or what?)
I've decided with this online shop i will go the whole hog and get new soap, pre-shave and aftershave treatments. I'm probably going to go for Wool-fat soap but don't have a clue what is a good pre-shave or aftershave, though i must note i've got sensitive skin.
Any suggestions for what i should buy guys? I'm not loaded so i'm looking to spend around £10 for each item, but i'll shell out a couple of quid extra for something 'well worth it'.
Apparently MFW isn't good for people with sensitive skin.
Orly? Oh, will reconsider then! I was under the impression it was designed for sensitive skin.
