What's a decent case to get for it? I quite like the iPad case that can wrap around.
To eBay!
My touchstone appears to no want to charge. Orriginially a pop up appeared something about not having enough something and to use a USB. Now nothing.
Any ideas for trouble shooting?
power source delivering 2amps?
Use a different microUSB cable (but use the same charger that came with it). My cable is utter pants and the touchpad won't charge from it.
It's the touchstone, as far as I know you can't change it.
It unplugs. Have you tried using the the charger from the TP?
you've got to power the touchstone from the mains adapter, it uses much more current than a USB Port can supply
Ah thanks, working nicely now. Kinda poo that I can't use the touchstone to connect to the PC though.
Mine is.
a "standard" USB port can only supply 0.5 amps, the touchstone charger uses a 2 amp mains adapter.
what ?
Thought what I quoted was aimed at me. Mine is plugged into the wall. Through the mains to usb adaptor. (the giant cyclander thingy)
) I've never had any error messages/edit/ try swapping the touchstone power adaptor with the one supplied with the touchpad
