Lying cable curls are awesome, nothing wrong with doing them at all. Although having the cable come from above instead of level with you is a must
I imagine doing them lying down focuses the work on your biceps more as your back will remain flat on the floor?
Aye, being tall is amusing...
I just don't see the need. If the weight is so heavy it can't be done with decent form why not drop the weight. Oh yeah, because curling less than 30kg doesn't impress anyone...
That's a ridiculous point of view mate, and I expect better from a seasoned lifter like you
It's not just about form, it's about ensuring you're always increasing weight when you can so you're not getting stuck on the same weight all the time. And if that means you're sacrificing too much form on normal curls, then use this exercise to get used to the weight and still keeping good form
And also, using a cable machine while lying down is a brilliant exercise because it's next to impossible to keep any momentum in the bottom of the movement so you're always getting the lift from a stand still rather than swinging
I suggest you try it before knocking it
2456 for bulking?
Haha, yea, bodypump is rough. My mate used to instruct the bodypump class at my gym and kept pestering me to come. I kept turning him down as I didn't think it would give me a good workout since it's just women and old men in there doing it. I finally relented a few months ago and went.
Well, halfway through I started looking for bins to puke in. Towards the end everything turned blue and appeared in slow motion and I could not grip the bars anymore. I fell asleep in the changing rooms for an hour and the next day I called in sick for work due to not being able to move without wincing in pain. Its difficulty is incredibly deceptive and I have a healthy new found respect for those 'women and old men' in there.
2 x Peanut Butter + Nutella on toasted Linseed and Soya bread
Calories - 876
Protein - 41.8g
Carbs - 43.8g
Fats - 57.4g
Fibre - 15.8g
