Thanks mate Does the venemous X wobble for ya? Its a great cooler and the black edition which i will buy is just sexy but the wobble put me off a lot.Apparantly you can turn the cooler if using the 70lbs pressure option.
I just want it with the normal pressure and im still worried about the movement with pastes that form bonds.Other than that things look good so ill check the thread in a day and see if my worries can be dispelled as im itching to get my hands on it with the gen 3, 2500k, 16gb ram and a gtx 580!![]()
Yeah i get a slight movement, I have tightened it a little and its not that bad, its not as bad as the Zalman i had running on my Q6600
I am waiting for the 6 series Nvidia's to come out so i can buy a gtx580 lol
Just got two OCZ Vertex 3's in RAID, i am shocked at the speed
