***The iOS 5 Thread***
You sir are a gentleman, that's worked a treat. Spent a while googling to see if anyone had the same issue but couldn't find anything.
Cheers mate :)
...and me wife calls me a geek ;) your welcome buddy
I had that particular brown trouser moment this morning after the update, let's just say the stuff that came out my mouth was worse than a sailors
Not iOS 5 related but i thought post here before a new thread. Sorry MODS, just trying to keep this Apple forum clean of little threads like this.
I have just made a document using some text boxes and when i send it to my dad he can't open it on his iPhone 4 ?
He has tried opening it using Pages also on his iPad and the text boxes, heading images etc aren't there just the actual numbers and writing.
Anyone help?
For some reason contacts crashes whenever I go onto someones info, and settings crashes when I go onto mail post ios5 update ive not set up icloud at all, anyone have any ideas how to sort it?
Cheers
Hawker
Is anyone finding that iTunes keeps opening on their PC since they have enabled sync over wi-fi?
Partially solved the problem, seems I had open iTunes when connecting the phone enabled. Either way I would still be interested to know what its actually doing, last sync was this morning when I had it on USB, but since then it has accessed iTunes every 5 minutes using the wi-fi.
well yes of course theres a point then
You can sync everything to the cloud so you'll never loose anything if the device gets stolen/lost/broken.
Just buy a new one and restore it all back on.
Thats fine, just thought it was more marketed for those with multiple Apple devices.
Besides as soon as I can ill be getting an iMac again.
Can someone tell why I can't verify my apple id?
I go onto my account and click the "verify email" and it refreshes the page and nothing happens, no email or nothing
Only got the one email address on there as well
Thanks
8 hours download time..... direct links don't do much better either.... 30mb is pointless with these servers.... need a direct link on a hosting site... google isn't showing much
