2x10x70kg squats
2x10x70kg SLDL
2x10x57.5kg bench
2x10x17.5kg db shoulder press
hit all the reps today
next 2 sessions are gonna be bloody hard though
@icecold if you read this. getting a bit of pain in my front delt on things like dips and in my supporting arm for dumbell rows. would i benefit from soft tissue work on it?
Yep almost certainly. Also remember to have your shoulder back and down in the socket for both movements, the soft tissues of your anterior shoulder get hot when your loading your shoulder when it's shifted forwards. When it's back in the socket you're supported by your entire shoulder structure so things are a lot more stable. You might find you need to work on some internal rotation stuff too.
Gonna try an HST workout routine again. Just so I can go to the gym 3x a week rather than 4 (also a big change and a lot less volume than I'm used to).
Currently looks like:
Front squats 3x15 (should this be 2x strictly rather than 3x?)
SLDL 2x15
CGBP 2x15
Bench press (barbell) 2x15
Lateral raise 2x15
BB row
Bicep curls (barbell)
Shrugs (forgot to do today)
Forearm reverse curls (not strict in number reps/weight)
Calf workout (~3 minute supersetted hi rep calf routine)
Just decided to do this starting today in my lecture, so a lot of the weights were a bit iffy for 80% 15 rep max, lord 15 rep squats take it out you!
Anyone think I should add anything? Chins/lats? (although I can't do 15 of them so it'll have to be on a machine!)
I'd try it more like this:
Front squats 2x15
SLDL 2x15
BB row
CGBP 2x15
Chins/pull ups/lat pull down
Shoulder pressing movement of choice
Should be better, although I'd possibly replace bicep isolation with lateral raises, you could do both if you didn't find it to be too much work. The order is going to be important, doing CGBP before conventional bench will leave you very tired.
Todays gym festivities included:
Squat 170kgx10x2 decided to belt up again as I'll need to do it at some point
SLDL 157.5x10x1 no straps
borrowed some but the guy had to go before I could finish
Inc. DB press 44(?!)kgx10x2 new gym doesn't have 45s
Pull up bw+10kgx10x2
Dips bw+37.5x10x2
HC2PP 65kgx10x2
and then some mobility and shoulder pre-hab. Good session!
