Reason is that avi files can't be added to iTunes so can't stream directly to ATV so has to go PC>iPad>ATV unless there is another way to get avi's onto the big screen?
Doesnt seem to be a native flickr app for the iPad 2can anyone recommend an alternative?
There's the Flickr app but for an alternative try FlickStackr as its a much nicer interface.Doesnt seem to be a native flickr app for the iPad 2can anyone recommend an alternative?
Well I'm using it so there must be![]()
The free one (FlickStackrXP) is functionally the same but you can only view the last 30 or 50 images in each view. Ended up getting the main version after using the freebie.Which app is that?
Thanks the free one?
