AMD Bulldozer Finally!
I won?
Oh cry less, seriously. Grow up. I could not give a toss whether you get an 8150 or not but do have gripes with people using bull reasoning. Assuming you could test what you wanted in-store giving you the same justification to DSR as another item is total and utter bull and you know it.
It's not even about DSR. It's the whole reason you need to use it at all - Apparently none of the data available online is of any use and you somehow believe you need an 8 Cored Bulldozer processor to run some magical software that runs so differently to what has been benchmarked already you can not glean one iota of information from it.
It's not like you are buying a radiator for a WC loop and are unsure if it will fit your case or not from what you can see listed about the item online. The CPU will work - End of.
u need to grow up tbh
since i asked a simple question about sending it back under DSR if im not happy with it, you and afew others have been getting at me.
If that was the case you should have posted it in Customer Support behind closed doors and not bleated on about why you wanted to still get it, then DSR it. Post such info in public, prepare to be 'got at'.
Basically it boils down to this.
You committed to buying it no matter what since day 1.
It launched and was terrible.
To save face you still intend to get one, but want a way out - DSR.
Sin_Chase your so wrong you don't know anything about me or my needs. i made it clear i would ONLY send it back if it didn't do what i want well in my OWN software
i gave just 2 EXAMPLES
just because u don't like people using dsr in this way doesn't give u the right to have a go at me, ocuk have said its ok.. if u don't like it don't reply..
but as i said i will send it back unopened,
sorry to the people who wanted to see the results but i don't need this crap from some people
Well looks like bulldozer is pants shame was hoping to see some Intel price drops end of this year for my new build.
For me the worst thing is the power usage of the Bulldozer an the best is the Box it comes in.:D
Well i am getting one delivered along with a CHV on monday if it is really that bad then i will get rid and drop my 1090t back in! I had really hoped some people would just get it and try and have a play with it for the banter.
