I won?
Oh cry less, seriously. Grow up. I could not give a toss whether you get an 8150 or not but do have gripes with people using bull reasoning. Assuming you could test what you wanted in-store giving you the same justification to DSR as another item is total and utter bull and you know it.
It's not even about DSR. It's the whole reason you need to use it at all - Apparently none of the data available online is of any use and you somehow believe you need an 8 Cored Bulldozer processor to run some magical software that runs so differently to what has been benchmarked already you can not glean one iota of information from it.
It's not like you are buying a radiator for a WC loop and are unsure if it will fit your case or not from what you can see listed about the item online. The CPU will work - End of.
