Battlefield 3 thread - Server details in opening post -
Status
Not open for further replies.
Course it will! having a larger FOV means there's more on screen therefore lower FPS. Playing at FOV 70 is same as consoles :yuk:. At 1080P you should be playing at 90, it also gives you an advantage online as you can see more on the sides.
No it won't. I see no fps difference using a wider FOV.
Its good, love it however...
What the hell is up with spawns? I get the impression the game chooses you to spawn next to an enemy if there is one? SO many times ive spawned and been insta killed by someone.
Had an amazing game on Damavand Peak last night, we where outside the tunnel after reaching the second position and just before i ran into the tunnel a little bird with two guys on each side comes swooping into the tunnel miniguns blazing, the two guys jump off and arm the site, the little bird gets hit with a rocket, load of enimes come pouring towards us, explosions, smoke, bullets.
The sound and visuals off it where similar to a blockbuster hollywood movie, just incredible.
No, why would it? fps won't change a bit.
Notsureifserious.jpg...
Obviously if the FOV is wider then there's more information to be processed. You can't just say that since the number of pixels hasn't changed then neither will the performance.
Be quicker then :p.
Think I might move over from conquest to rush for this evening. Sounds epic :D
So now that the game is out...
Does it perform negligibly better than the beta? Will those of us with older series graphics cards perhaps have acceptable performance?
Thank you
Status
