Wouldnt that destory my fps?
No, why would it? fps won't change a bit.
Course it will! having a larger FOV means there's more on screen therefore lower FPS. Playing at FOV 70 is same as consoles :yuk:. At 1080P you should be playing at 90, it also gives you an advantage online as you can see more on the sides.
No it won't. I see no fps difference using a wider FOV.
Crossfire users, are you still using the BF3 Beta driver?
I'm a bit gutted that the stats will be reset![]()
Does anyone else agree that explosions in this game are AMAZING?
The sound, the visuals, they're brilliant. Jet and chopper crashes are AWESOME![]()
Its good, love it however...
What the hell is up with spawns? I get the impression the game chooses you to spawn next to an enemy if there is one? SO many times ive spawned and been insta killed by someone.
Had an amazing game on Damavand Peak last night, we where outside the tunnel after reaching the second position and just before i ran into the tunnel a little bird with two guys on each side comes swooping into the tunnel miniguns blazing, the two guys jump off and arm the site, the little bird gets hit with a rocket, load of enimes come pouring towards us, explosions, smoke, bullets.
The sound and visuals off it where similar to a blockbuster hollywood movie, just incredible.
I'm using 11.9 with cap3, game is running great on ultra with 2 x 6870s and AA turned off.
