Done something stupid on eBay
well still its very cheap for an rx8.. one on pistonheads is 2050 for a crashed one.. you should be able to get it back..
Could be as simple *cough* as new coil packs, HT leads and hotter spark plugs.
Could be a engine rebuild.
More likely to need both anyway.
Pretty straight forward to rebuild from what I remember (could be wrong though?) so might not be all that bad - or am I thinking about the 7?
The front end looks a bit iffy to me.
Yea I asked about the bonnet he said it was the picture!
I got 2 owners when I did a hpi?? Which is why I then emailed saying your friend was the first own can you find out what history it has from speaking to him !
RX8
No history
No bills
Warm start problem
Owner only had it 3 weeks
Owner will consider any reasonable offer
Nothing could possibly go wrong...
His friend was the second not the first. HPI is showing you previous owners.
That's not bad considering even if it needs a few parts. A family member eBayed a bog standard non-running 2006 Mk2 Focus 1.6 which needs a new engine for £1400 last week.
Please, trivialise the likely engine replacement as being 'a few parts' some more :D
An RX8 which needs no parts can be had for £3k.
It's showing 2 owners current one would be second so the guy he bought it off would be 1 surely??
He doesn't know it needs a new engine. Could be a £50 fix.
Anyway how much does a fully running Focus go for?
No, the HPI check shows you the number of PREVIOUS registered keepers. This is also the figure the DVLA holds.
Therefore the car has had 3 keepers if the HPI check records two previous. You will be the fourth.
Like I said.
