- 23 Sep 2011
- London
Anyone managed to get audio via HDMI from the onboard HDMI port? no audio for me?
BTW, I love how it overclocks a 2700k to 4.6 stable with changing just one setting in the BIOS.
What one setting is that?
Will the Cooler Master Hyper TX3 get in the way of 16GB of corsair vengence?
I have ordered both and never thought!
I love the board but I have an issue with my sennheiser USB headphones/mic not working properly on occasion. A re-log sorts it.
Anyone else had this issue? If so, did you find a fix?
I haven't flashed the BIOS yet and I'm sure its a USB driver or USB support issue.
Wondering if anyone else has had this problem before I go trying to fix it.
Read the thread on XS forums mate - Use the drivers they recommend there, not the latest ones![]()
I was pretty disappointed with my corsair vengence. If you have a really close look at them you can see that the thermal tape on the heatsinks don't quite touch the memory chips. If you squeeze the heatsink it will touch the chips but will come a way again if you stop squeezing.
bumps mine to about 1.29v>1.30v - which is well within spec mate
One user he has reported that it didn't work for him though, but I think he has a poor 2700k which doesn't clock well as he needed more vcore.
Dunno if there is a way to fix this or taking the heatsinks off and puting some paste on the memory chips would help.
Or removing the heatsinks as all they are doing is insulating the memory chips if they don't touch....
4.6 profile takes my vcore to 1.41 sometimes. Is that realistically gonna be an issue? Using a 2500k.
