If he does a lot of typing he will love the blues, if the clicking noise is going to bother him you could look at some o ring dampers to lessen the noise.
New QPAD MK85 is due out soon with cherry reds and full n key rollover from usb
It's a usb keyboard so it's not "full" n-key rollover. It will be restricted to 6 keys including modifiers.
Apparently not http://www.corporate.qpad.se/modules/news/article.php?storyid=248
The QPAD MK-85 is the world's first mechanical keyboard offering full N-key roll over via USB. Since the PS/2 connector is being phased out and several manufacturers of computers and motherboards do not offer this option, many gamers are left with no way of utilizing the benefit of the full roll over feature, because their gaming rig does not support that type of connection. With the MK-85, this will not be a problem
I wish there was a useful (but functionally useless) MX tester pad you could buy which had several clusters of keys each with different switch types, so you could physically get your hands on blues/blacks/browns/reds etc and see what you liked the feel of best.
What's with all the mechanical keyboard I see here before me? Am I missing something?
I also linked this a while ago, might help you some what.
http://www.mrinterface.com/simulators
Just click simulator on whatever keyboard you want to try, then start typing.![]()
Been looking into a new keyboard for a while and noticed this thread. I'm a sucker for seriously good quality components and build quality but want something for gaming, with typing out essays etc as a secondary consideration. Due to that, which out of the mechanical keyboards OcUK sell would you guys recommend for me? I don't want something that is very loud to type on and would prefer a backlight + PS2 connector to stop polling if possible.
Price range isn't an issue
Thanks in advance!
You limit your options there, the noise aspect takes out blues, but i also would say blacks and reds are not the optimal switch for typing. The brows are probably your best bet, so you can go with the ZOWIE Celeritas, everything but the backlight, or the MK-85, though that has a USB(with NKRO).
