*** The 2011 Gym Rats Thread ***
Status
Not open for further replies.
Alright now Icecold?
Monday
Chest:
Incline Bench Press 5x5
Bench Press 5x5
Chest Dips 3x10
Pec Dec 3x10
Biceps:
EZ Bar Curls 3x10
Concentration Curls 3x10
Forearms:
Reverse Grip Barbell Curls 3x10
Wednesday
Legs:
Squats 5x5
Leg Press 5x5
Shoulders:
Standing Military Press 5x5
Standing Dumbbell Lateral Raise (sides) 3x10
Standing Dumbbell Lateral Raise (front) 3x10
Dumbbell Shrugs 3x10
Friday
Back:
Wide Grip Pull Ups 5x5
Deadlifts 5x5
T-Bar Rows 3x10
Seated Close Grip Pull Downs 3x10
One Arm Dumbbell Rows 3x10
Good Mornings 3x10
Triceps:
High Pulley Overhead Tricep Extensions 3x10
Skull crushers. 3x10
Yes, but (again :p), you need more leg volume. If you only want to squat you need to do more sets on that day or do 5x5 twice a week. You haven't said why you don't want to do stiff leg deads/romanian deads or reverse DB lunges, so I don't know what to suggest as alternatives.
I do a lot of rambling up the South Downs where a lot of the ground is uneven and inclined my legs will be fine just doing squats. :p
The virgin active I went to had a very similar squat rack to that, only difference was it didn't have moveable catchers.
Awesome bench session tonight although it nearly turned to ****. Worked my way up to 120K in an empty gym, gave it 10 minutes then decided to go home because I needed a spotter. A mate turned up as I was walking out the door :eek:
Bench
60k x 10
80k x 10
100k x 10
120k x 5
140k x 5
150k x 1
160k x 1 (10kg PB) :D
100k x 21
Squat and deadlift PB attempts on Friday :cool:
Started using my dumbbells tonight to get myself started. I'm tiny compared to pretty much everybody at 5' 10" and about 11.5 Stone and very weak.
Started off on arms to see how I get on, 3x15 Hammer curls then 3x15 skull crushers and now my arms feel like they might fall off, I guess thats good? Only a pathetic 3.5k on each dumbbell as thats about all I can manage and actually complete the sets.
No clue if I should be doing less reps and more set on a higher weight or what, any tips?
Its hard going when you are doing it for a couple of hours! Anyway squats are good enough for me.
It's fine if that's all you'll do, but it certainly isn't anywhere near "enough". Most strength athletes will at least do SLDL or front squats as well, and reverse DB lunges are awesome for your core stability.
Bench
60k x 10
80k x 10
100k x 10
120k x 5
140k x 5
150k x 1
100k x 21
Huge bench! Great work
Cheers dude.
Felt like the speed work I did last week really helped tonight. My sticking point's always been the first few inches off my chest but everything up to and including 150 flew up today. Think I might include speed work in my routine for a month or two after Christmas depending on how my shoulders feel. They did not like speed week! :o
Would squats and seated leg presses be enough for a leg routine?
Cheers dude.
Speed work?
Cheers dude.
I've been working on my bench recently by holding the bar at my chest for 2 seconds before pushing it out. So far I've managed some decent weight this way which will hopefully mean I can beat my PB of 160kg. Been able to do 130 x 4 followed by 140kg x 3 this way. Bottom part is the hardest part after all.
Speed work?
50-60% of your 1 rep max for an exercise done as fast as possible to increase force and explosive strength.
I usually do these on my static days although I've never found them that beneficial.
Status
