Man of Honour
- 5 Jun 2003
- Falling...
Seated leg press and squats will do nicely?
If it works for you mate go for it!
If you won't do anything else it's better than nothing, but I wouldn't ever choose it over SLDL, front squats or reverse lunges for a strength routine.Would squats and seated leg presses be enough for a leg routine?
Yeah I love speed work, I'm currently doing speed bench and speed squats (off a box) every week. There's not really room for speed deads on a regular basis, but I'm going to try and fit them in when my regular deads get heavy.Cheers dude.
Felt like the speed work I did last week really helped tonight. My sticking point's always been the first few inches off my chest but everything up to and including 150 flew up today. Think I might include speed work in my routine for a month or two after Christmas depending on how my shoulders feel. They did not like speed week!![]()
I'm not going to do front squats as well as normal squats that'll drive me nuts, its one or the other! The shoulder isolation is because I want strong rotator cuffs.If you won't do anything else it's better than nothing, but I wouldn't ever choose it over SLDL, front squats or reverse lunges for a strength routine.
There are a few other things in there that are superfluous for a non-bulking strength only routine.
pec deck
forearm work
leg press - somewhat open to debate
shoulder isolation
...all things that are more bodybuilding orientated. That's fine, but that's not what you said you wanted.
Sorry if it seems like I'm being overly critical, not my intention to be a ****![]()
Be careful with your shoulder, big benchers tend to get very tight in the pec and anterior delt. If nothing else, a little soft tissue work with a lacrosse ball will help massively.
Exercising my forearms to match my upper arms just makes sense as I'll look ****ing odd with big biceps and small forearms. also whats the point of SLDL if I'm doing deadlifts? Should I skip the pec dec then?
This what you talking about? http://www.mobilitywod.com/2011/07/episode-286365-trigger-point-world-headquarters-shoulder-mob.html
Looks very similar to meEh? SLDL's are completely different to deadlifts![]()
I think it's down to how hard you hit your hammys tho mate. Yes, you might be hitting them, but not anywhere near as effectively as doing an exercise than specifically targets the hammy as a primary muscle group.
Looks very similar to me![]()
I don't doubt that, but they look very similar!Believe me, an SLDL / Romanian DL will hit the hams more so than a standard deadlift.
It helps if you bring your knees right back to your chest and have your heels of your feet planted wide apart at the edges of the plate.
Know doubt they will, but I'm sticking to what I know as there are alternative exercises to hit the hamstrings which I personally find effective.An SLDL will target the hams more due to more 'resistance' presumably, and the movement.
However wait till someone clever comes along to explain further![]()
Have to choose a half decent gym first lol, I'll be looking at a Fitness First and a Virgin Active Thursday afternoon.Fair enough
Let me know how the parallel squats go
