- 3 Oct 2009
- Wales
STOP CHANGING THINGS FFS
It's not hate it's just every few days you seem to want to try something new or worry about your diet. Eat 3500 cals, pick a routine and see how you're doing in 3 months![]()
I have been
Just asking the questions so I know for future reference, the bodybuilding game is a constant learning curve for me, so I like to know things should I wish to try them
P.S: How's the back?
Squatted on monday and felt ok, just a little weak in the core. No pbs this week though i guess.
Ok, but 25 reps of squats per week is not enough! Look at how much work you're giving the rest of your body, to then only put that much into your legs is criminal.I'm not going to do front squats as well as normal squats that'll drive me nuts, its one or the other!
Again, the shoulder isolation you are proposing will not help keep your rotator cuff healthy. I'm not sure where you got that idea from, even the traditionally "good" rotator cuff exercises don't include front and side raises. Also, rotator cuff exercises should not be performed in the same way as conventional exercises - going anywhere near high levels of resistance will cause the bigger shoulder muscles to take over.The shoulder isolation is because I want strong rotator cuffs.
I don't do any direct work on either. My biceps aren't small and my forearms are pretty big comparatively. Peoples forearms end up small because they don't actually use their grip. The only thing I use straps on is power shrugs, but I'll let myself off considering that I'm bouncing 250+kg around for reps.Exercising my forearms to match my upper arms just makes sense as I'll look ****ing odd with big biceps and small forearms.
Because they work in different ways, and are actually quite different. These, or romanian deads, are the best hamstring exercise going.also whats the point of SLDL if I'm doing deadlifts?
It's fine to keep it as long as you think of it as a mass builder only.Should I skip the pec dec then?
Great, but that only makes you strong on the leg press. I have a friend who moves silly weight around on a leg press but squats less than 150kg. I'm not saying don't use a leg press, but it does nothing for your core, so you don't actually get to transfer any of the power of in your legs to do anything useful. I certainly wouldn't go as far as to say it's an exercise only useful in bodybuilding, but it's less useful for strength than the other things I posted.From previous experience of using a leg press with well over 600 kilos on it I was hitting my hamstrings. I guess what works for some wont nessisarly work for others.
I know, it can seem pretty complicated. It's important to fully understand your goals. When you say you want strength, what does this mean? Do you want to move big numbers on the leg press or bicep curls, or do you mean in terms of more practical usage such as strongman? If you want a bit of mass, then train for it.I guess what people need to grasp about me is I have only ever lifted for fun kind of thing and my focus was all on lifting big and not so much on the nutritional side of things, which I now know goes hand in hand.
I do want strength and endurance but wouldn't mind a bit of mass. I'm learning new things here but there is so much to take in.
Yep that's the one. Butcher your anterior delt where you're at it. Moving your arm around can expose different areas of tightness, in particular moving it into internal rotation (e.g. arm behind back) can reveal some nastiness.This what you talking about? http://www.mobilitywod.com/2011/07/episode-286365-trigger-point-world-headquarters-shoulder-mob.html
Do you do any core work currently?Squatted on monday and felt ok, just a little weak in the core. No pbs this week though i guess.
*puts on Limp Bizkt - Take A Look Around*
*downs pre-workout shake*
Time for some squatting.
I can't wear earphones in the gym I just get distracted by them - I just get on with it.
my face was the colour of beetroot
