So are there any decent cases out there yet? A quick web search seems to show the normal 1.99 dross from ebay currently.
Hoping switcheasy will do something similar to a neo capsule for the GNex.
Arrrg, spent too long running customs ROMS now i have the Nexus, how do you:
disable/enable GPS?
turn the torch on?
does this phone have a status LED like my old Desire?
you will have to look on the market for that what torch?you will have to look on the market for that
(i blew my led on my desire using the torch)
yes it does have led status, lots of people using liteflow to change colours too
Had my first freeze and crash today. Was using WhatsApp and Messaging app when it froze and I got strange red artifacts.
Couldn't turn the phone off or anything, thankfully it turned itself off. I then pulled the battery and booted it up and it was all fine again.
Don't know what caused it but hopefully it was just a glitch.
i think crashes come from the apps not being setup for ics. in time they will all get updated
disable GPS in the settings, or do what i do and add a widget for all my controls
It honestly doesnt have the option? Settings > Wi-Fi (on/off), Bluetooth (on/off), Data Usage....more....Airplane mode, tethering NFC, Android Beam, Wi-Fi Direct, Mobile Networks.
Also purchased that 10p HD Widget app but thats missing it. Hmmmm
no idea why anyone would buy an iphone over this. Dont miss my iphone4 at all which i was worried i might.I know, but it gets rid of the google search bar, gives my 5 rows of icons per homescreen and scrollable widgets like calendar, emails, fb etc
Theres an option in the menus to remove the search bar...
where is this option ?
